Couldn't find your picture
Reading the blurb mentions:-
"Triple protection which enables the cable to resist even the most hostile
of environments. exceptional flexibility.
Used extensively in construction, food processing, heating and air conditioning installations"
"The MF CX Cable Gland is designed for use with Steel Wire or Copper Wire Braid Armour.
Manufactured from brass and encapsulated with a non-corrosive polyester outer body,
offering complete protection in the most hostile of environments.
For EMC environments braid placement is critical,
for optimum performance the braids are terminated 360 degree around the periphery
of the cable entry as opposed to using a pigtail technique.
This broad footprint of braids against gland wall yields low transfer resistance
and high EMC protection.
Seals on both the inner and outer cable sheath, to IP68 if fitted with a sealing gasket".
I'm not sure
The cable doesn't look super rodent, puncture, mechanical damage or UV proof.
I'm sure someone else will qualify..........
