curlydon said:50m coil 32mm mdpe approx £25
2 hockey sticks approx £ 7
2 sleeves " £26
Fittings each end " £30
All plus Vat. + copper to boiler.
Or go for SS tracpipe about £10.50/m dunno whether you can get 25m coils tho.
kevplumb said:250
7 cu m2 an hour
Welski said:Just been outside...measured up its 24 metres from meter to the pump room and then a further 5 meters along inside that to the boiler.
As a question would that be plastic coated pipe underground then jointed t onormal copper along the inside wall?
doitall said:Sat in a hotel room with the night porter I could miss anything, but that another story.
Was trying to find out if the heat exchanger is direct or indirect, if direct dont buy it.
doitall said:Welski said:Just been outside...measured up its 24 metres from meter to the pump room and then a further 5 meters along inside that to the boiler.
No nice yellow looking pipe, the last meter in the ground (both ends) will be steel denso taped then above ground can be steel or copper.
