Well I've no real experience other than what I have read on forums, but I'll try to answer:
Yes the switch does click and the burner does light. It sounds like it normally would when running hot water (even without the CH on)
I don't know what 'linking out' the switch means and don't have a meter to test the switch connections. I guess I'm just trying to gain as much insight into the problem for when a heating engineer comes out to it (my friend has been called away, so I'm having to call-out someone else!)
Is the switch the most likely source of the problem?
