how do I add a new radiator into my conservatory
4 May 2023
Im looking at putting a radiator in my conservatory ,the house it in 10 mm plastic how would I need to do this please
A) you shouldn't do it unless you also install a separate zone valve on the leg feeding the conservatory.
B) You'd need to run 2 new lengths of 10 or 15mm tube from the system manifolds to the conservatory -10mm plastic internal diameter is usually too small to run multiple radiators from.
Do not tee into 10mm for new rad it wont work as per above new feeds need running from manifold or before it
Building regs for not allow radiators in conservatories and haven't for several years, even with separate time & temperature controls. Get a split air conditioning unit
Oops- didn't realise that had changed :(
