you may welded the contacts A-B together when you blew the fuse, use a multi meter to see if you have continuity across A and B with the power turned off.
Is diagram B for wiring direct to the boiler, I am connectting to valve via the junction box should I connect via dia C? if so is brown equilvant to the old white
