Hi All,
apologies for another boiler post but I've looked at several years worth of posts about the subject and haven;t quite found my situation described...
My Ideal Boxer C24 keeps cutting out.
It works for a couple of minutes (with the pump going) before stopping.
Burner flames are full on for a few seconds before reducing (half-size) until boiler cuts out after a few minutes.
Radiators get lukewarm (hence the house is freezing!)
Hot water is fine and works continuously.
If I turn thermostat off and then back on it restarts fine - before cutting out again.
Turning the pump speed up helped the boiler run marginally longer.
The combined pressure/temperature gauge: pressure fine, temp gauge not working.
Any ideas/thoughts greatly appreciated....
Mark
Mark
