First is a oven with a connected load of 3.8kW hard wired to double pole switch using 6mm cable. Second is oven with a total connected load of 3.6kW, I was going to hard wire this using 6mm and both bonded using 10mm, however the oven arrived with 4mm white three core flex and a installation note. Do not connect with plug, connection must be with a all-pole disconnection device with a minimum contact gap of 3mm. Above Ricicle says 'All pole means double - pole for a single phase install' which both would be connected to using 6mm for each, but can I wire in to a 30amp junction box with the 6mm and then out with the 4mm factory fitted to the oven.
Reason for not going straight to the double pole switch from the oven, using 4mm is that it would mean pulling all the cabinets and splash back out, to get the 4mm in to the box, the wife won't like that. I did wire a 6mm from the box into the cabinet awaiting the oven, but the thing turned up with a 4mm flex. I thought that a 30amp junction box would be fine, but so that I don't void the warranty, any advice would be appreciated. Thanks again.
