Hiya, I've lived in this property for 5 months now and with Winter fast approaching I'm concerned about the bare pipes in my loft.
It's only a 1 bedroom maisonette so there isn't too much up there and it's only the radiator pipes, the tap pipes just go through walls from the boiler.
Should I buy this stuff and cover as much pipes as I can?
http://www.toolstation.com/shop/p48736
Am I write in thinking that the 13mm is the thickness of the foam, and the 15mm & 22mm are the pipe diameters?
Do they need to be zip tied onto the pipes? Or can they just sit loose?
I'm looking at getting my main loft insulation increased soon (is currently 100mm), if I get this up to 300mm is the pipe foam even needed?
Some of the pipes run dead parallel to each other so I think I'm going to struggle to get foam around them individually?
A couple of random pics (it's pitch black up there)...
Thanks for reading
Thanks for reading
