cold chisel
Now I've been thinking about one of those babies! Any new power tools must, of course, be completely over specced for the job. Where do I put the petrol?
cold chisel
That's not an angle grinder.
and an angle grinder may be more use to me and will do the chasing job adequately.
You can then spend the rest of your life getting rid of the dust.
Club hammer and bolster is the tried and tested method, its also the cleanest.
Why don't read the posts before gobbing off, the op said he was going to use an angle grinder thats what I was responding to.
You know what, holmslaw, I'm getting quite sick of your attitude towards a great many people on here just recently. Quite frankly, I think it stinks. If you can't manage to construct a polite response when someone disagrees with you, I suggest you take yourself elsewhere.
You seem to see imaginary additional words in sentences and are prone to exageration. You imply that I have upset many people, well no ones complained to me. Be best if you grew up a bit, learn not to lash when you make a mistake.
[Could I suggest that if you can't bring anything constructive to the table, don't come to the table in the 1st place
Could I suggest that you keep your stupid nose out of things that are above you're mental capacity.
Edit - I think I've seen whats got your back up - the thread about 25mm holes. It is not my fault you are unable to appreciate the difference between a hole saw and a hole punch, educate yourself read my contribution.
I've never had any problems taking a 20mm knockout to 25mm with a holesaw. I can see how using a punch would be problematic, though.
I've got one, and I gave it a test the other day (in the garage) with a boggo-standard domestic vac attached (Electrolux, i.e. not even one of the quality makes), and the results were encouraging enough for me to plan to give it a go in the kitchen this weekend. Certainly didn't seem as though it would be any worse than SDS chiselling...I suspect the people who criticise wall chasers have not used one hooked up to a good workshop vac. I borrowed the exact same one as shown in the picture above from a friend, hooked it up to an Earlex Combivac and used it for chasing in some pipework at home. It made far, far, far less mess than using a hammer and chisel, and despite the scaremongering from holmslaw above, your room does not fill with dust as long as you use a vac!
