- Joined
- 16 Dec 2004
- Messages
- 13
- Reaction score
- 0
- Country
Your intermediate switch would have 4 wires and the luminaire is controlled from 3 or more locations, \
Tom
Tom
Notice that they explicity include the grounded conductor of a 2-wire system as being a neutral. That's why my fellow Brits are so insistent that this usage is correct. And yes, I'm aware of the fact that the first part of the IEE's definition in relation to a 3-ph 4-w system is rather circular in its nature and not the best way they could have defined it!Neutral conductor. The neutral conductor of a 3-phase 4-wire system, the conductor of a single-phase or d.c. installation which is earthed by the supply undertaking (or otherwise at the source of the supply), or the middle wire or common return conductor of a 3-wire d.c. or single-phase a.c. system.
SwindonSpark said:In case you are lost in this thread, here's a picture: -
BAS,ban-all-sheds said:We call the two conductors Live and Neutral. You call yours Hot and Grounded, I believe?
They can, but it's a matter of historical development. In earlier times American homes did take a 2-wire 120V-only service (some are still in existence). When higher-powered appliances started to become more common, and homes started to use greater quantities of power in general, 240V supplies were provided. To have changed to a straight 240V 2-wire service would have rendered existing 120V equipment redundant.notb665 said:Why would a house need two different voltages? Surely appliances can be designed to work on one voltage like in the, er, UK.
When having a 240volt 'receptical', is fed from a double pole breaker, or 2 single pole breakers??
Lectrician said:When having a 240volt 'receptical', is it fed from a double pole breaker, or 2 single pole breakers?
Thomasj845 said:Would you agree or dis agree that a neutral conductor is a conductor designed to carry unbalanced current?
TOm
Paul_C said:A double-pole breaker is the norm, but two single-pole breakers are also permissible so long as an approved handle tie is used so that both poles will open simultaneously. (A standard residential panel has the busbars interleaved so that adjacent slots will always be on opposite poles.)
