OK Tony I will type this really slowly so you can understand, the diverter valve if stuck in the DHW position, which I have never heard of then the heat would not go to the radiators and the boiler would be constantly short firing untill a hot water outlet was opened and removing the switch would make absolutely no difference what so ever as the switch was already in demand before removed. you have absolutely no Idea how this boiler operatesIan, you are missing the point!
When the switch is removed it initiates a DHW demand condition.
Where the heat goes, depends on the position of the diverter valve.
At rest, the heat goes to the rads.
If a tap is turned on, the diverter valve moves and the heat goes to the DHW.
I appreciate that Dan is the one with an English degree but surely others can understand simple English?
