Why can you paper over linning paper , when if you try papering over old paper the paste tends to wet the old paper enough to start it peeling off as if you were trying to strip it
thank you all
stavros
It all depends on how it was hung If it has been well soaked and applied properly and it isn't a vinyl , washable or heavily embossed, then you can paper over paper , as long as your joints dont fall together and nothing is going to bleed through.
When hanging lining paper -1000 - how long should it be soaked considering i have given the wall a quick going over with paste first ??
thanks folks
Stavros
thanks folks
Stavros
At the very least - 20 minutes, I always leave it longer. Hang it too early and it will bubble up. Pasting the wall first is irrelevant to how long to soak the paper.
i normaslly leave it about ten minutes..thats plenty.
Its no different to any other paper really..
As for papering over paper..never ever never...papering over lining is fine but as for normal paper id never do it..id rather turn a job down you can have grief at the tops bottoms and internal corners.
You might get away with it..if you dont then you will have wasted your time and the cost of the paper.
If the paper bubbles up ut rarely goes back and it ends up looking like a massice circus tent on your wall.
