Now, now. No need to insult or denigrate certain forum members!!Isn't the problem with Wago boxes that you can open them without a tool?
Bureacratically (per Mr Jobsworth) that's true - but, AFAIAA, they did not change the boxes, but merely added the 'MF' marking and included instructions as to how to use Wago connectors within them for them to be compliant with MF requirements. Once old stocks are all sold, I presume that all Wago boxes will bear the MF label.For the OP - not all wago boxes are Maintenance free. The box must have the MF marking
In common sense terms, that isn't much of an issue if they're inaccessible. However, I believe the answer is that you're meant to put a cable tie or somesuch through the (provided) lug; the knife, cutters, scissors or whatever required to gain acess will then count as a 'tool'!Isn't the problem with Wago boxes that you can open them without a tool?
... the knife, cutters, scissors or whatever required to gain acess will then count as a 'tool'!
Kind Regards, John
You didn't necessarily misunderstand - you could add whatever you had in mind to my list, if you felt it could successfully release a cable tieIt appears I misunderstood the inference of the word "tool" in my last post. My apologies. I've been reading too many long threads today that seem to degenerate into, for wont of a better description, cat fights.
That's why I'm personally no fan of any sort of inaccessible joints
FWIW, same here.Me neither. I will if I really have to do a through joint on a cable, but that's all I'll do if the joint is to be inaccesible. I won't 'tee' into a cable or do a loop in joint etc. anywhere that can't be accessed at a later date.That's why I'm personally no fan of any sort of inaccessible joints
Indeed - and, as you know, I personally don't really trust crimped joints enough to be very comfortable with them being 'eternally inaccessible', either - soldered is about the only thing I might feel a little more comfortable about, and that only if I knew and trusted the person who'd done the soldering! As for what sort of 'legacy' joints still exist in a few places in my house, that's a secretI still don't trust these MF junction boxes enough to stash them away where you'll never get at them again.
Got to say that, if new install being done, that is now my preferred method.I nearly always loop in at the switch these days.
Kind Regards, John
That information is out-of-date. You now know of two - but please note that 'prefer' is only a relative term; I am not comfortable with any sort of 'seriously inaccessible' joint (e.g. buried in paster).There's only one person I've ever known to not like crimps and prefer solder.
I doubt it, and 'no', respectively.Have we met in the past? Do you play guitar at all?
