I am thinking of putting a PIR in the attic bedroom to turn on the attic light automatically - currently there is a two-way light circuit with switches at the top and bottom of the stairs but I dont like having to find the top switch in the dark near some stairs! I am hopeful that sleeping movements from the bed on the other side of the room wont trigger the PIR. (current config is LN feed into top switch, 3 core down to bottom switch, 2 core from top switch up to ceiling rose)
I am wondering on different configurations:
1. Replace the top light switch and convert to a single switch at the bottom + PIR in parallel at the top
+keeps the switching easy to identify - "off" at the bottom switch means PIR is in control.
+can override PIR ON time using downstairs switch
- feels like there should still be a switch upstairs but I guess no real need? What if PIR fails?
- No way to force the light off as PIR can always trigger
- Cannot force the light on from upstairs
2. Keep the two-way and add the PIR in parallel
+ can override the PIR time limit from upstairs
+ can override the PIR time limit from downstairs
- No way of knowing if switch or PIR has the light turned on as two-way switches cannot indicate if they are "on"
- No way to force the light off.
3. Make bottom switch power up the whole circuit and top switch move between PIR or forced on
+ can force light off using downstairs switch
- cannot force light off from upstairs
- unusual switch layout, might need switches labelling
- lights wouldnt come on when turning bottom switch on (or do all PIRs trigger when first powered up?)
Is there a better option without adding additional switches? Option 2 biggest drawback is not knowing if the switches currently have the light on or the PIR so am swayed away from this. Its a kids bedroom if that makes any difference to the suitable options.
