This should sort out the wheat from the chaff
I'm trying to understand how to manipulate water pressure using this equation:
p=F/A
where: p=pressure
F=Force
and A=Area
1. How do I find the (p) pressure? and what is it measured in?
2. How do I find (F) the value of force? and what is it measured in?
3. And (A) is the area of what? The cross section of the 22mm pipe, the 1m2 tank, or what?
My Example:
I have a water tank of 1 cubic metre capacity, which has a mass of 1 Ton or 1000 kilos or 100000 grams.
The tank has an open ended 22mm pipe exiting its base, 1 metre in length.
Question 1. What is the water, that is flowing out of the 22mm pipe measured in: pressure units/force units/metres per second/newtons?
Question 2. If I were to double the size of that water tank to 2m3, ie 2 Tons of water, would that extra Ton of mass make the water exiting the 22mm pipe, exit faster? would the pressure and/or the force of that exiting water increase?
I have more questions, but I just want to get my head around these points first.
Thanks for your help, and all the best for the new year!
p=F/A
where: p=pressure
F=Force
and A=Area
My Example:
