True, but there must be a receiver which requires power, and connection to the boiler.If you're talking about the wireless sensor/transmitter, that presumably requires no wires at all (the clue is in the "wireless"!),
The idea of a battery powered receiver would be pointless because it can be placed near the supply and/or boiler.
The one in your link states " All models in the range are available in hard-wired and wireless versions".
Because, I think, if not used as wireless it allows different temperature ranges and, because of the battery, can operate with only the two wires present and has a display.so I'm not sure why they would comment specifically that it was ideal for upgrading a 2-wire stat. I think I must be getting confused!
If used as wireless then it is conventional and the receiver may as well be put in the right place.
In either case, it does not seem to have a clock but merely a day/night selector switch.
It, presumably does not have the transmitter if you do not buy the wireless version (that would be a waste but nowadays, who knows?)
The thermostat on its own is £32.
http://www.heatingcontrolsonline.co.uk/danfoss-randall-retb-room-thermostat-p-243.html
There are also better ones than this which are fully programmable (times and temperature) which are battery powered so can use the two wires.
http://www.honeywelluk.com/products...-Digital/CM907-7-Day-Programmable-Thermostat/
