Funnily enough was watching Cowboy builders last night and in the property under the investigation the builder had a shut of water valve directly above the consumer unit and obviously pipework carrying water in that vicinity.
The EXPERT and melissa were both shaking there heads and saying how big a no no this was.
What i didnt get was? obviously quite rightly it does seem like a massive NO NO NEVER thing to do, but is this a regulationary thing.
I enquire because in a renovation I am undertaking, i have a fixed (cast in stone) position for my consumer unit, meter etc. directly above this is the bathroom, and although I can keep all the domestic water and waste completely away from above the consumer unit, I am left with one position only were i can fix the Radiator/towel rail, which will be directly above the consumer unit etc.
Basically at gound floor at almost ceiling level i have CU coming out of the top of this are my circuits between joists, also in the vicinity, but not adjacent to, i will have the 15mm flow and return of the central heating feeding the Rad/towel rail. to some extent the valves of the said rad will be directly above the CU, seperated byfloorboard, joist, plasterboard.
What are the regs on this??
If regulation allows i will do it, however not without tanking in such a way as water would never be able to discharge from the rad to the CU.
All advice appreciated.
Russell
Russell
