My house is fitted with a Range Powermax 155x. I moved into the house just before Christmas and took out British Gas Homecare in case of any problems.
The Powermax had a couple of lockouts in January, it became a weekly event in February, and this month it is happening just about every day. If I switch the unit off for 10 seconds or so and then back on again it works fine (though I have noticed that it makes a sort of groaning noise when it ignites - does this indicate something?).
Once, on re-starting after a lockout, the green burner light came on momentarily three times then it went straight into a lockout again. Does this mean the pilot failed to light? Could this be the source of the problem?
When the system was inspected by British Gas back in January it passed with flying colours (I mentioned the lockouts to the engineer at the time but he just said it's a "feature" of the Powermax and it didn't seem that big a deal back then).
I check the pressure regularly and this seems to be fine (no leaks, running at about 1.5 when cold). I topped it up about two weeks ago and the pressure has stayed relatively constant ever since.
I get the feeling that if I call British Gas they will just say that there's nothing wrong (I can't get the unit to lockout on purpose so proving the fault to them might be awkward). Is there a list of obvious faults that would cause a lockout? Are there any simple diagnostics I can do to isolate the fault?
