Got a small plastering job in an office, don't want to make any mess and it's on the 15th floor, no room to mix up. Is this stuff anygood. Going on to plasterboard.
It will do a job but really for patch/repairs.
What area are you covering as it is costly in comparison?
Is there a location outside available for mixing or a nearby room that is suitable?
Because regardless of any thing else you will still have to get a mixed up version to the office area.
Have since used the product from various companies and can quite safely say there all ****e! Should have bit the bullet and made some mess. I thought I was being clever. Didnt cover the angle beads would barely cover the scrim. It's dries unevenly. It's just glorified filler. Although could have obtained a better finish with Tetrion. The one positive is that it did sand down well. Thank ****.
Should have listened.........
