Hi All
Old wood floor is currently glued straight onto concrete (50-ish years old, very dry!). Old wood floor is 12mm thick. It got ink spilled on and insurance has paid out for new floor. We're planning on getting a nice new wood floor and the supplier has some 23mm thick stained pine stuff we like.
Trouble is... they recommend 2 x 1" battens on the floor first. Now the gap between the base concrete and the underside of the door is about 25-30mm, so we have space without touching the door IF we stick it direct to the concrete. However, if we stick in 1" battens first, that's going to lift the whole floor up a good inch to inch and a half above the (carpeted) hall floor level, leading to an almost invisible step into the front room, which EVERYONE will fall over...
Anyone else solved this problem before?
