I am having my flat roof & boarding (on my extension) replaced, however am not sure what thickness the ply should be. All are 6mm, but should I use 50mm, 70mm, 90mm or 110mm? My roof is 6" by 12". Many thanks for any advice.
What is it currently?I am having my flat roof & boarding (on my extension) replaced, however am not sure what thickness the ply should be.
It's currently 6mm?All are 6mm,
Instead of 6mm? Bit of a jump.but should I use 50mm, 70mm, 90mm or 110mm?
I wouldn't advise using plywood 4.33" thick on a dolls house.My roof is 6" by 12". Many thanks for any advice.
Seriously BAS, are you really that retarded?What is it currently?I am having my flat roof & boarding (on my extension) replaced, however am not sure what thickness the ply should be.
Can you actually get plywood that thick? Why do you think you might want it to be that thick? Have you thought about the structural implications of such a huge weight of wood?
Why do you ask that?Seriously BAS, are you really that retarded?
That's just a question of course you understand, I'm not actually saying YOU ARE RETARDED.
So what are you then, if you think it's a good idea on seeing words written by someone to pretend that they have written something else?I can only conclude from your ramblings that you are retarded.
I wrote 1 post in reply to the OP.why you have to make such a song dance about everything is a mystery.
I apologise for my wife (who was the one who wrote the enquiry in the 1st place), she's not a ****** or a bas****
BAS said:You and cjard have now made 5 about my 1.
