Salus RT500RF Programmable Room Stat Questions
You need to understand that the RT500RF is a Programable Thermostat, it is not a Programmer.
However you can easily put the heating off continuosly by either;
-use the frost button to put it into frost protection mode,
-or put it into sleep mode (by holding down both arrow buttons for 3 seconds)
(Six period settings would give the flexibility for midday periods and this will be in future products).
al21
i know you work for salus, whats the inside info on the new range? (the one that looks a bit like an i pod!!)
cheers
only seen it briefly bingo, it looked to me there was no "buttons" more like a touch screeny,i pody kind a thing
might have been the gasinstaller mag that i saw they were at installerlive with an all new product line up, just checked their site,nothing new there
Hi.
I have problem. My thermostat shows sign LO, and it's doesn't turn off automaticlly. Can anyone tell me whats that mean?
Hi.
Probably not been fitted high enough :rolleyes:
Make and model would be good, as well as starting another topic.
Hi.
Usually that means the battery needs replacing because the output is "Lo".
You can buy them in the Polski sklep.
Tony
The reason the stat is coming on during the night/ always being on is setting number 5, there are 5 settings on the Salus
1 is the time you want heating on eg, 07.00 and set the temp (20)
2 is the time you want it to go off eg, 10.00 and set the temp (10 this will turn it off)
3 is the time to come on an evening eg. 17.00 and set the temp (20)
4 is the time you want it to go off eg, 23.00 and set the temp (10 this will turn it off)
5 the problem many people have is that they do not set number 5 correctly, this is a night/ frost stat and if you don't set the time and temperature same as 4 ie, 23.00 and 10*c then the heating will stay on.
I have had quite a few customers who struggle with the instructions so i typed it out in plain English as a word document and give it to them so its easier, if you want send me your e-mail address and i will mail it to you.
