Sizing up an accumulator
24 Jan 2011
Surrey
Does anybody know where to find tables or calculations to size up an accumulator
somethign that takes into account the flow rate in and the usage
This is how I do it.
Calculate your demand eg 3 showers using 10 litres a minute for 15 minutes = 450 litres
Mains supply = 20 litres a minute over 15 minutes = 300 litres
Short fall is 150 litres.
So should be looking at maybe 200 litre unit.
Beware though the 200 litre unit would then take approx 8 minutes filling
again from the example above.
That is incorrect.
There are a few variables, if you want the unit sized for you why not ask the manufacturer to do it for you.
You will find a 200 litre virtually useless with three showers.
You will need to know the static water pressure, the i/c flow rate and the likely drawoff over a period of time.
On larger jobs we get the manufacturer to underwrite the solution, and we've done nearly 100.
The static pressure is 2.5bar and the flow rate is arround the 15l per minute
I can call GAH out advise me
Simond,
i read on other replies that you install the TWS system
in particular the TWS mainsboost accumulator,
what is your opinion on these
It's a breaker tank & pump you need mate, accumulator will not cope with that demand or on such a low static pressure.
We replaced two with a breaker tank system last year, the demand at peak times were too high.
take a look at the RM mains boost (accumulater) & charger unit (pump) set up ??
I din't think that 2.5 bar was really that low?
I did had a look at that RM mains boost and looks very similar to tws or coldstream, but i cannot find the reseller for RMmains boost
