Wot is 'jumbo'?try a proper merchant for the timber etc.
3 x2,cls,or even jumbo.
100mm betwixt studs and as much as you like across them prior to plaster-boarding.So what thickness celotex would you use?
Have you checked with your council to see if any PD rights have been removed, which will mean you can't do that without permission?We are converting half of our double garage in to a room
You will need to use at least 100mm (regularised to 97mm) thick timber in order to accommodate the thickness of celotex required.
It's a double garage - is it really under 30m²?do you need building regs if the garage is not attached to the house?
Cheaper (in general), plus 6 month returns policy. You can't beat that on a long project.Any reason why they are better than any other shed?
Its about 5 meters away.
