WF321 Aquarius Washing Machine Mini Load+ Power Lights flash
25 Feb 2013
I've been having various problems with this washer - it seems to have an intermittent door locking problem (the program will start, then after a few seconds the door lock light goes out and the program stops. repeat..) When I try a spin only, it makes some noise, but doesn't spin, and then the mini load light and power light start flashing. I've seen that this may be "motor triac" fault - what does that mean?
Ian
Check motor brushes are not worn. Otherwise pcb is shot.
