What are these I found loose amongst my bathroom refit bits
They look liek components that fit inside your taps, to create a champagne effect or standard flow
bathstyle is right,
low pressure sometimes causes the water to dribble out of your taps so they are removed to increase the flow
they are the little bits the last plumber dropped when fitting it all :D
Flow restrictors from the shower. Usually a couple of different colour ones come with the showers (brown, yellow, green)and the one most suited to the system is used. Check the shower MI,s and it will tell you.
I'm guessing some kind of device to restrict the amount of water through a fitting of some kind :LOL:
What a response!!
Thanks everyone, I shall try to stick em in my shower, if they don't fit, Ill stick them in my ears.
