Why is the plumbing system the way it is here?
Unvented cylinder with system boiler, and a house approx 20m below a reservoir if you insist on 60ft head (= 2bar):LOL: :LOL: :LOL:
60ft head no that's for *****'s I want 90 ft head 2 showers simultaneously no pumps. Surely it depends upon the flow ??
So now you want 3 bar? As you've no doubt worked out by now 1 bar is approx 10m of head. It does depend on both pressure and flow rate.
To get an understanding of this, think of a common hose with an adjustable spray head. You could get a varying flow rate regardless of the fixed incoming pressure by adjusting the spray. And if you used a wider bore hose, then the same applies. It is entirely possible to have exactly the same flow rate using a narrow hose with high pressure as a wide hose with a low pressure. So both flow rate and pressure come into the calculation for a powerful shower.
http://cgi.ebay.co.uk/300Ltr-Unvented-Hot-Water-Cylinder-Direct-Brand-New_W0QQitemZ280381485607QQcmdZViewItemQQptZUK_Home_Garden_Hearing_Cooling_Air?hash=item414809f227&_trksid=p3286.c0.m14
isnt it illegal to sell an unvented cylinder now without the water set and EV??
nope it's not about BAR, my jet wash wallops out 110 BAR, but would make a ****e shower.
to comply with Building Regulation G3 they must be supplied with a complete package of controls - either factory fitted, or supplied as an unvented kit
Any unvented hot water storage system should be in
the form of a proprietary unit or package
Mick that doesn't prevent them being sold legally but it should prevent them being installed, and yet it doesn't.
I must be misinterpreting the regulations then. I would thought if someones selling something they're supplying it, but then I guess when you stick it in the van and take it to missus you now become the supplier as well....just another unenforcable regulation i guess :rolleyes:
nope it's not about BAR, my jet wash wallops out 110 BAR, but would make a s***te shower.
But it would get you clean ;)
Anyway, you brought up the subject of bar when you specced 60 then 90 foot of head. Nar na na nar na ;)
A good shower would probably need about 10 to 15 lpm, so for 2 to be run simultaneously you'd need about double this incoming mains supply.
There is also the case for replacement parts - it is entirely possible to buy one bit without being forced to have to buy the whole package.
I think the regulation is pretty clear, anything over 15l and you must have a G3 ticket to install or service an unvented cylinder.
In our places in France
150 - 200 litre unvented hot water tanks
shower run off bath taps, one of which the hot water tank was about 15-20metres of 14mm copper pipe away
