That's a mid-position valve, not a diverter. A diverter can have ports AB & A open or ports AB & B. A mid position can also have ports AB & A & B open. Port AB is always open. The valve be in one of three positions: A open, B open, A and B open.MAV-322What other numbers are there on the valve?
The Delta needs a mixing valve, controlled by a server motor, to work. This can take up virtually any position between A fully open, B closed to B fully open A closed.
OK.It is an A3 sheet size of diagram is not to scale but measures 32cms w x 21 cms ht, the only bits missing are the left side of the page, I think, abd only show the layouts for H & C secondary supplies to the bathroom, kitchen, utility and en-suite - showing Ippec's preferred supply manifolds as opposed to standard plumbing Tee's. There are no further valves at all here.How big, (cm x cm) is the layout diagram you took a pic of? Some of it is missing so,
Can't see how the system will work without a mixing valve upstairs. As it stands the upstairs underfloor is being fed with water at the boiler temperature(70-80°C); it should be much lower. The ground floor is OK as the 3-way valve will mix some of the return with the flow and reduce the temperature.Not sent and not installed, when asked why it had not ben sent, they decided it wasn't really necessary! Though when I think it through - if this mixer is intended to reduce the temperature of the UFH flow to the manifold - then why not? unless it can be reduced by other means? -the only other control for 1st floor is the room stat. I thought I had tagged this on the drawing I posted - sorry if not! It is easy enough to put one in if better, since all the pipe-work is contained within and easily accessible in the cylinder / control cupboard.second 3-way valve in the 1st floor circuit. I had wondered why your diagram did not show one. Can you confirm it is there?
If the 3 way valve was between the HW cylinder and the 1st floor circuit, it would act as a mixer for both ground and 1st floor circuits.
The diagram you posted from IPPEC also shows a pump (as well as the missing valve) on the first floor. Presumably that is also missing!
I don't see what they were playing at - and I doubt if they did either.
Don't think that will help.On the Ippec web page I found wiring diagram for Delta23b/w100 control for UFH & radiators
I think you may have to get someone in to look at your system and advise what must be done.
