But according to you it is a sausage. You said that if the manufacturer called it a sausage then it would be a sausage.Of course not ... Because it is not edible or even eatable; it merely has the same name.
if, because of its shape, the manufacturer called it a sausage then that is what it would be.
So (assuming you eat sausages), why would you not eat it? It's a sausage.
That makes no sense - you have assured us that it is, in fact, a sausage.As above.If you bought a sausage roll, and it contained one of those wrapped in flaky pastry, would you think that was OK?
If not, why not?
Not without a proper framework for definitions, and you've said that redefinition isn't necessaryI don't think it is difficult to understand that some completely different things have the same name - let alone some things with the same function.
So you think that without a redefinition of {a word}, if someone simply calls something {a word} then it does genuinely become {a word}.They don't have to redefine.
Even if it did not have the same function, that would still be its name.
Since you seem to be unable to grasp the idea of the difference between a product name and a name describing the nature of an item, we are left with only your clearly stated opinion that simply calling it a blackberry makes it a blackberry.Because it it not edible; it just has the same name.As per above, if a handful of them were stewed with apple, and served in a dish covered with pastry, would you eat it?
If not, why not?
So assuming you eat apple and blackberry pie, why would you not eat a pie made with some of those blackberries from BlackBerry Limited?
No - I'm saying that unless the word transformer is officially redefined something which transforms voltage is not necessarily a transformer.Are you saying something which transforms is not transforming?
A transformer is an electrical device that transfers energy between two or more circuits through electromagnetic induction.
A varying current in the transformer's primary winding creates a varying magnetic flux in the core and a varying magnetic field impinging on the secondary winding. This varying magnetic field at the secondary induces a varying electromotive force (emf) or voltage in the secondary winding.
