just to add , the Pressure at normal is set to 1. and I have reduced the HW and CH teamp dials to 2 - made no differerence - and yes the boiler would appear to be overheating - I banging my head against the wall in time to the boiler
have you checked the expansion vesselr1gwh said:thanks for the info so far- I have tonight just run the CH Only. its ok for about 15min then the pressure needle jumps up and boiler shuts down Leaving the CH demand light on but nothing else. the previous night I just run the HW and again I get hot water for about 4 mins then the pressure needle jumps and the boiler makes very loud banging sound, with the odd bit of steam venting. when I run the CH and then also demand some HW we are ok for about 30 seconds before the pressure needle jumps and the boiler shuts down making lots of loud noises. and yes sometimes both HW and CH lights flash slowly - hope this makes sense.
AS it's on ch and hw , it would point to the pump being sludged up , or running slow. The impeller is like 2 circular plates with a 4mm gap between, which can fill up with goo.as the overheating problem was happing on both HW and CH I rulled out the pump - please correct me if I'm wrong.
