Worcester 24i Combi
24 Oct 2005
Just come in from work tonight and went to run the hot tap - and nothing just cold water.
CH also not heating the rad's.
opened the front panel and the pilot gone out.
The instructions to light (for a 28i) say turn on electric, then turn the temperature setting to max.
Is this right? as its not working.
or is there another way to light the pilot on one of these?
cheers
It has electronic ignition and lights the main burners.
Have you pressed the reset button.
Is the system pressure between 1 - 1.5 bar.
Try the re set button on top of the boiler on the right (not the test point beside it)
