I need a 3 port actuator head,, please can anyone help as they seem to be scarce, is it possible to interchange (ie. use a honeywell body and head) or do I need to aquire the manufacturers actuator.
The Heatslave valve is a diverter valve designed for HW priority, whereas the Honeywell one you find in shops at weekends is a mid-position valve.
The Worcester one will also have a bespoke plug to the PCB. So unless anyone knows a way to cheat it's the makers powerhead needed. You may find parts stockists open tomorrow.
Even though the powerheads have to be the same make. I suppose if another whole diverter valve fit in the space you could rob the connector block from the old one as long as WB use standard colours (not sure they do). Be easier and less risk getting original part.
