DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Oil boiler keeps cutting out.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Ori
from United Kingdom
PostPosted: Tue Oct 09, 2007 12:01 pm Reply with quote
My central heating oil boiler keeps cutting out. It is a Myson Volaire Pressure Jet 50/70. The system was drained when new radiators were fitted, with new pipe routing in some cases. The boiler fired up fine but only ran for a few minutes before cutting out and initially only heated the pipes upto to the upstairs cupboard where the flow and return pipes start to go off to the radiators. I have bled the radiators and after waiting 10 - 15 mins fired the boiler again only for it to cut off again. The pipes are heating up further along the flow on each occasion I go through this process but the radiators no longer release any air when bled. The boiler runs for approximately 4minutes each time now. Also there is a thermostat ranging from -15 to +10 (never seen that type before). what should the setting be? Any advice would be greatly appreciated. - The oil flow is fine
Is it an airlock? and can this be removed by draining the system out from the boiler ( which is the lowest point), whilst allowing the header tank to fill the system or does it need to be drained off completely first?
Back to top
 Alert Moderators
wilhelm
from United Kingdom
Thanked: 1 time
PostPosted: Tue Oct 09, 2007 12:16 pm Reply with quote
sounds like air lock. I usually back off one of the top connections on the boiler, and see if air or wasser comes out.
your cold feed may be blocked?
Back to top
 Alert Moderators
Ori
from United Kingdom
PostPosted: Tue Oct 09, 2007 2:07 pm Reply with quote
Thanks Wilhelm,
I thought an air lock maybe the culprit but had not thought of your suggestion. I will try that out but excuse my ignorance for asking about wasser/water?
The cold water feed seems okay as all the radiators have filled up and the header tank stop cock has engaged.
Would it be easier and appropriate to drain and refill again?
Back to top
 Alert Moderators
wilhelm
from United Kingdom
Thanked: 1 time
PostPosted: Tue Oct 09, 2007 4:02 pm Reply with quote
well there is no flow from the boiler, so you need to get the pipes filled up somehow,
is it a bungalow?
is boiler in garage?
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 26 times
PostPosted: Tue Oct 09, 2007 4:45 pm Reply with quote
Hertfordshire is big if you are on roller skates. Which bit?
You could try turning off all rads except one, then run the pump at full speed.
Back to top
 Alert Moderators
Ori
from United Kingdom
PostPosted: Tue Oct 09, 2007 9:22 pm Reply with quote
No air just water came out the boiler but have noticed that the pump is sticking and stops which seems to be what has caused the boiler to shutdown. A bit of manual intervention seems to have sorted it out and the hot water is this moment flowing around to the radiators. Thanks for the advice it was helpful in eliminating potential causes.
Thanks again
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ferroli Boiler 77FF Cutting Out 5 120 Mon Feb 17, 2014 7:40 am
Feroni/Ferroli FalconII boiler burner cutting out/restarting 6 1980 Tue Jan 12, 2010 1:02 pm
alpha boiler cutting out 4 540 Fri Oct 09, 2009 12:29 pm
Ideal ICOS M3080 Boiler cutting out 3 80 Thu Jul 25, 2013 6:31 pm
Flow rate - Glowworm boiler cutting out 4 1000 Mon Dec 14, 2009 10:17 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
