DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Flow Rate for 10mm plastic pipe.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
willp2
from United Kingdom
PostPosted: Sat Oct 13, 2007 6:05 pm Reply with quote
I read the post on Smiths under plinth heaters there was no ref to size of input pipes, I wish to spur off the heating system with plastic 10mm will this support enough flow rate (70gph) I think is what is required. I have a Combi system
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 815 times
PostPosted: Sat Oct 13, 2007 6:24 pm Reply with quote
Can't see a problem with this, 10mm usually will take up to 10,000 btu's.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3595 times
PostPosted: Sat Oct 13, 2007 11:54 pm Reply with quote
It all depends on the length of 10 mm tube!
And the rating of the heater!
Because these are such good heaters I would normally fit with 15 mm to ensure they get enough heat input.
I would ask why use 10 mm ??
Tony
Back to top
 Alert Moderators
willp2
from United Kingdom
PostPosted: Sun Oct 14, 2007 2:55 pm Reply with quote
because I'm lazy and 10mm is already in situ from the rad I'm changing it with thanks anyway
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun Oct 14, 2007 3:15 pm Reply with quote
So, you're actually sharing the heat capacity of 10mm between the rad (and maybe more than one) and the plinth heater.
I wouldn't use microbore unless it was illegal not to - if the system isn't clean enough it'll block up quicker than you can say "magnetite".
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 20 times
PostPosted: Sun Oct 14, 2007 5:15 pm Reply with quote
[quote="Softus";p="714078"]
I've never known microbore become blocked by corrosion deposits. 15mm pipe on the other hand can become blocked. The reason is that water travels at higher velocities in microbore and is less likely to leave any deposits.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun Oct 14, 2007 5:22 pm Reply with quote
Chris, my comment was meant to be in context - I've seen it happen where a plinth heater, because of the nature of its use, is out of circulation for long periods, and there can be a build up where the supply tees in to the rest of the circuit. I've also seen a plinth heater that seemed to act as a sump for every bit of grunge in the system, and defied attempts to clean it out. And don't forget - the velocity through each rad (and plinth heater) is independent of the water velocity in the supply pipework.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Joining 8mm Microbore to 10mm plastic CH pipe 3 80 Sat Mar 15, 2014 7:43 am
Fitting radiator with 10mm plastic pipe from behind 4 160 Tue Dec 02, 2014 2:57 pm
15mm/10mm plastic or copper 2 500 Tue Nov 29, 2005 2:45 pm
Advantage of 10mm over 15mm plastic for CH rads? 5 140 Wed Aug 03, 2011 9:34 am
Mixing 10mm Plastic and 15mm Copper on one Radiator 6 160 Thu Mar 14, 2013 2:38 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
