DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Electric shower not working
This topic originated from the How to page called Fitting an electric shower
Click here to return to the page called Fitting an electric shower.
  View previous topic :: View next topic
Author Message
mdg35
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 16, 2007 3:50 pm    Post Subject:
Reply with quote Thanks
Hi All
Electric shower has stopped working. Basically, the light on the pull switch is on until you turn on the on switch on the electric shower, at which point the light on the pull switch goes out and nothing happens. Anyone got any ideas?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
luminaire
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 16, 2007 4:02 pm    Post Subject:
Sounds a bit weird if it was working satisfactorily before.
I would check the connections in the switch make sure they're good.
Then check the wiring on the shower.
Make sure you're switched off at the CU first.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Fri Nov 16, 2007 4:08 pm    Post Subject:
Back to top
 Alert Moderators
mdg35
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 16, 2007 4:09 pm    Post Subject:
Well, I know it is not the shower unit as I changed it and the same thing happened. Guess maybe the next thing is to change the pull switch?
Back to top
 Alert Moderators
mdg35
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 16, 2007 4:14 pm    Post Subject:
Thanks Steve, but what does "burnt out neutral" mean I have to change?
Back to top
 Alert Moderators
luminaire
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 16, 2007 4:15 pm    Post Subject:
What is the size of your shower?
Also what size cable are you using?
Back to top
 Alert Moderators
mdg35
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 16, 2007 4:32 pm    Post Subject:
Shower is a 7.5kw Aquatronic
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Fri Nov 16, 2007 8:07 pm    Post Subject:
Sometimes everything, sometimes very little.
Open the switch and see if I'm right.
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Fri Nov 16, 2007 8:33 pm    Post Subject:
It sounds like a high resistance somewhere - either a burnt connection or poor switch contact.Enough current can flow to light the neon but when the shower is switched on the voltage falls away and so the neon goes out.
__________________
Empty barrels make the most noise.
Back to top
 Alert Moderators
carter123
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 19, 2007 3:21 pm    Post Subject:
im having the same problem with my shower unit.
I turn it on from the pull cord the light comes on but the shower does not work at all.
Should i buy a new switch first or would you think i need a new shower.
The shower itself is about 7 years old and was fitted by the previous owner.
any suggestions ?????
Back to top
 Alert Moderators
IrvWorth
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 19, 2008 12:10 pm    Post Subject:
I have same problem...
i have the same problem - did you manage to sot this out (i guess you must have by now)?
The shower was here when we bought the house but seems quite new, and the switch was put in by electricians when we had the whole place rewired 6 months ago. I checked the isolator and the neutral does appear to a be a bit blackened. Do i just replace the switch or does it mean that there is a bigger problem?
Cheers
Al
Back to top
 Alert Moderators
DESL
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 19, 2008 12:23 pm    Post Subject:
Give them a call they should come and check it over.
If it was rewired 6 months ago the switch and wiring will be under warranty - don't change the switch yourself
Back to top
 Alert Moderators
IrvWorth
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 19, 2008 2:14 pm    Post Subject:
Thanks, will do.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
electric shower not working 2 300 Fri Jan 09, 2009 4:42 pm
Electric Shower Not Working – Please Help 4 780 Fri Apr 20, 2007 3:34 pm
Kitchen electric sockets not working - fuse box ok 2 140 Wed Mar 18, 2009 6:20 pm
Electric plug sockets have stopped working 27 1220 Fri Oct 12, 2007 3:50 pm
shower not working 5 180 Sun Apr 05, 2009 12:52 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
