DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Shower switch light always on?
Author Message
cam23
from United Kingdom
PostPosted: Fri Jun 27, 2008 4:21 pm Reply with quote
I've just wired up a new pull-cord switch for our shower (a 45A DP ceiling switch). This switch has both a red pilot light and a dial that reads 'On' or 'Off' as you pull the cord. I looked carefully at the existing wiring and the wiring diagram; there were basically 2 sets of red(L), black(N) and green(E) wires and I have wired them up as per the diagram. When I try it, all seems well as regards the shower - the shower's own light comes on in line with the 'On/Off' dial on the switch. However, the small red light on the switch itself is on all the time. This doesn't seem right, but the light's wiring was already set up inside the switch when I unpacked it, and there's no detail on the wiring diagram specific to the light (the pilot light on the old switch never worked, so I couldn't use that as a guide either). Does anyone have advice or suggestions? Thanks in advance.
Back to top
 Alert Moderators
electronicsuk
from United Kingdom
Thanked: 275 times
PostPosted: Fri Jun 27, 2008 4:24 pm Reply with quote
You have wired the supply and load side terminals the wrong way round. It wont change the operation of the switch, but it is misleading and potentially for anyone wanting to isolate the shower for maintenance.
Back to top
 Alert Moderators
cam23
from United Kingdom
PostPosted: Fri Jun 27, 2008 4:40 pm Reply with quote
Thanks for the quick reply. Forgive my ignorance but I'm not sure I understand 'side terminals.'
There are 2 large cables coming out of the wall, each consisting of a set of 1 live, 1 neutral & 1 earth wires. I assume from the diagram that one of these bunches is the supply and one the load? So, do you mean that I've wired ALL of them the wrong way i.e. I need to swap the 2 earths around, the 2 lives, and the 2 neutrals? Sorry, first DIY wiring job. Thanks again.
Back to top
 Alert Moderators
cam23
from United Kingdom
PostPosted: Fri Jun 27, 2008 5:13 pm Reply with quote
OK, I think I see the problem. The red light is connected at one side only to reflect the state of the switch. I guess I need to swap all my connections over. Thanks for the help.
Back to top
 Alert Moderators
electronicsuk
from United Kingdom
Thanked: 275 times
PostPosted: Fri Jun 27, 2008 5:16 pm Reply with quote
Yup, you're right, you need to swap all the connections over.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
power shower supply from light switch? 12 1900 Thu Jun 29, 2006 11:17 am
45 Amp shower switch red light always on? 2 760 Sun Apr 26, 2009 5:27 pm
Shower Pull Switch - light not coming on 5 120 Mon Oct 17, 2011 5:35 pm
Shower switch light on - constantly 9 460 Sun Jun 14, 2009 1:55 pm
shower pull switch neon light stays on 14 7280 Sun Oct 24, 2010 8:36 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
