Hello,
I have an 8 year old Potterton Puma 80e - and it appears to have decided to have a problem when the CH demands hot water. I can hear the pump running, but the flame does not light to give the hot water. So I have just switched the CH switch to off, pending some assistance hopefully from yourselves!
When I switch on a hot tap, the pump runs and also the flame lights - so I have no problems with hot water. I fear however that if the CH is not working, I am probably likely to have no Hot water soon.
I don\\\'t get a very good flow rate of hot water, but I don\\\'t expect great performance from my combi. It is worth noting that I live in a quite high limescale area, however I have an electronic device which removes limescale from pipes - so hopefully the heat-exchanger is not limed up. I would say over the last few weeks the boiler has \\\'locked-out\\\' on occasion (once every 3-4 days at around 8am).
From other posts here - it sounds like the Hot water Demand Switch could be at fault? What are your thoughts.
Many thanks.
Many thanks.
