longbloke
Joined: 27 Nov 2004 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Sat Nov 27, 2004 9:04 pm Post Subject: New FCU for bathroom floor heating |
How can I tell whether my combi boiler is connected direct to the main ring or as a spur (I can't trace the wiring back as it's hidden).
I'm hoping to use a spur from the combi's FCU in the airing cupboard to connect underfloor heating, but presumably you can't run a spur from a spur?
Thanks  |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 21983 Location: London, United Kingdom Thanked: 78 times
Posted: Sun Nov 28, 2004 10:44 am Post Subject: |
You say that the boiler is on an FCU - opening that up will tell you whether it's on a spur or on the ring.
1 cable = spur
2 cables = ring, or possibly on to another device (which it shouldn't) - you'd need to disconnect both cables on the supply side and see if one or both are live.
IMHO it is 99.9999999999999999% certain that the FCU is not directly on the ring, and yes, you're right, you can't spur off a spur to power something else.
What is the load of the U/F heating? __________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth. |
delmel
Joined: 28 Nov 2004 Posts: 323 Location: United Kingdom Thanked: 0 times
