DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Combined fused spur and socket?
Author Message
Hibbo
from United Kingdom
Thanked: 4 times
PostPosted: Wed Dec 09, 2009 12:16 pm Reply with quote
Hello!
I'm going to be running a fused spur, it will be taken from where there is currently a standard double socket. In the interests of efficiency (ie laziness), I am wondering if a combined fused spur and single socket unit is available that would fit in the same back-box as the current double socket. I've never seen such a thing, and I'm guessing I'll have to install a new box for the spur, but I just thought I'd ask!
Cheers.
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Wed Dec 09, 2009 12:37 pm Reply with quote
Back to top
 Alert Moderators
PrenticeBoyofDerry
from United Kingdom
Thanked: 1180 times
PostPosted: Wed Dec 09, 2009 12:57 pm Reply with quote
hibbo,
does the spur need to be fused?
how many sockets will you be running from it?
can you extend the circuit rater than spur?
Back to top
 Alert Moderators
Hibbo
from United Kingdom
Thanked: 4 times
PostPosted: Wed Dec 09, 2009 1:41 pm Reply with quote
The spur will be supplying a garden shed, that's why I want it to be fused (and switchable). I know the best plan would be to run it from an extra breaker at the CU, but I have decided to go with a spur from the kitchen.
It has to be flush mounted really, so for the work involved to fit the dual box I may as well just fit an extra single...
Thanks for the replies
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1353 times
PostPosted: Wed Dec 09, 2009 2:08 pm Reply with quote
How far away is the garden shed?
What will the load be in it?
What type and size of cable will you be using?
How will the cable be installed?
Is the circuit you're spurring from RCD protected?
What type of supply do you have?
Are there any extraneous-conductive-parts in the shed?
What tests will you carry out on the cable once installed?
Back to top
 Alert Moderators
Chri5
from United Kingdom
Thanked: 321 times
PostPosted: Wed Dec 09, 2009 2:35 pm Reply with quote
Since it takes a 13a fuse surely it counts as a f/spur with sockets icon_biggrin.gif
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1353 times
PostPosted: Wed Dec 09, 2009 4:31 pm Reply with quote
I'd love to see you use one to supply a permanently connected cable on the load side of the fuse.... icon_biggrin.gif
Back to top
 Alert Moderators
Hibbo
from United Kingdom
Thanked: 4 times
PostPosted: Wed Dec 09, 2009 4:49 pm Reply with quote
There will be two 60w lamps, and a couple of sockets (which will have nothing more demanding than basic power-tools plugged in to them). A 13A supply will be plenty.
I am using 2.5mm^2 SWA cable, the run will be about 30m. It will be secured to a brick wall.
The house has a TNC-S supply, and has a 30mA RCD protecting the kitchen circuit from where the spur will be taken.
There are no extraneous-conductive parts in the shed (it's entirely wooden)
I will Meggar the complete spur before I connect it to the FCU, and after connection I'll do an earth-fault-loop impedance test from the shed.
Thanks for you concerns, does my plan sound safe?
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Combined Fused Spur & Socket Outlet. 21 5260 Sat Jan 09, 2010 3:12 pm
45 amp cooker switch combined with socket? 8 680 Mon Jan 18, 2010 3:32 pm
Combined 1 gang socket + TV aerial socket? 14 520 Fri Jan 14, 2011 11:40 pm
Combined socket and FCU. 5 540 Tue Jul 03, 2007 12:07 pm
Combined MCB/RCD 8 400 Wed Aug 29, 2007 6:45 am
DIYnot
