DIYnot
Local | Network
   DIYnot > Forums
Local | Network
"live" neutral wire
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
ripvan
from Australia
PostPosted: Sat Mar 01, 2003 5:17 am Reply with quote
I'm having a problem hard wiring a new circular fluoro light in place of a tube fluoro.
When I removed the existing cabling from the back of the old fluoro housing, I didn't mark what went where.
We now have no hardwired lights working and at the new light the neutral is "live" continuously. When I turn that light switch "on" both active and neutral are "live".
At the junction box (for that light) in the ceiling cavity, there is the cable coming from the previous light, a cable that dead ends 6' away in another junction box, a cable that presumably goes to the next light, and a cable which goes to the light switch.
What I have done is
1. connect all the earths together and extend down to earth connection on light fitting
2. connect all the actives and extend down to one side of light switch
3. connect other side of light switch to active connection on light fitting
4. connect remaining neutrals and extend to neutral connection on light fitting
I think I have the same as the bottom image at: http://www.diydata.com/planning/electric_lights/electric_lights.htm#wiring
Can anyone suggest where I have gone wrong?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sat Mar 01, 2003 7:21 am Reply with quote
hello ripvan, what you have written is correct, however you say We now have no hardwired lights working and at the new light the neutral is "live" continuously. When I turn that light switch "on" both active and neutral are "live".
Although the drawing you refer to is correct you may find this one easier to see where you have gone wrong.
Back to top
 Alert Moderators
ripvan
from Australia
PostPosted: Sun Mar 02, 2003 12:38 am Reply with quote
Hmm, I replied to you last night breezer, but it hasn't shown up icon_sad.gif
What I asked was is it possible for an live neutral to be caused by an open circuit within the loop?
I rerouted (without disconnect/reconnect) some cabling and maybe a wire has broken at a connector somewhere?
Thanks for your time...appreciate it.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sun Mar 02, 2003 7:38 am Reply with quote
yes because you can get a backfeed through a lamp. Are you using a meter and does this say your neutral is live?.
If you are using a meter then if you find which is the cable going to the switch, the OTHER cables can be conected red to red black to black etc.
Also if you have moved any other lights i should check there for a broken wire.
(there does seem to be a problem with this particular post, i posted, it said "problem sending email" but my reply was there
Back to top
 Alert Moderators
ripvan
from Australia
PostPosted: Sun Mar 02, 2003 8:47 am Reply with quote
fixed it!!
I am using a test lamp that my dad (was an electrician, lol) made in 1954.
When I moved the cabling around I broke a wire at the next junction along.
Repaired it....bingo!
Many thanks for your help breezer.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Live Wire! 5 1020 Wed Nov 20, 2002 3:22 pm
Corrosion on Live wire of shower pullcord switch 2 860 Fri Mar 21, 2003 1:20 pm
Permanent live wire 2 5240 Sun Sep 01, 2002 4:39 pm
tensile steel wire, shower curtain 4 2340 Sat Jul 31, 2004 12:14 pm
Earth wire to fuse box 12 7500 Mon Jun 09, 2003 10:37 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
