a client wants his fridge freezer on a non rcd protected circuit and this is no problem as long as the cable route does not require it and it is labelled as such. So installing a cable from the cu in surface trunking is ok, but i need to drill through a wall to pass the cable through and then continue in trunking, but 6 inches will be buried???? comments please, (edited bit) so 50mm on each side will be technically buried
