DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Linking bathroom extractor fan to main light switch
Goto page 1, 2  Next
Author Message
ben85
from United Kingdom
PostPosted: Thu Jan 13, 2011 3:02 pm Reply with quote
Hi All,
When I moved in this year in my house I noticed in the bathroom there was an extraction fan. This did not turn on when I turned on the light (as I expected). I then looked up and could see a fan isolater switch. I then turned this on and the fan did not run.
I suspected the fan was faulty, fitted a new one and it thankfully worked!
I would now like the fan to turn on when I turn the bathroom light on as at the moment I have to turn on the fan by the isolater switch by standing on top of the bathroom bin and manually turning the b*****r on.
Just to give you sparkies some more information. The switch for the bathroom light is outside the bathroom near the door, the isolater switch is near the ceiling (I believe to meet certain electric regs) and the fan is in the ceiling near-ish the isolater swtich.
Regards,
BW
Back to top
 Alert Moderators
riveralt
from United Kingdom
Thanked: 565 times
PostPosted: Thu Jan 13, 2011 3:07 pm Reply with quote
Have you bought a fan with a timer or is it a standard fan?
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1924 times
PostPosted: Thu Jan 13, 2011 3:08 pm Reply with quote
Is it a timed-overrun fan?
Does your lighting loop run through the lights, or through the switches?
electrics:lighting:fan
Back to top
 Alert Moderators
ben85
from United Kingdom
PostPosted: Thu Jan 13, 2011 3:15 pm Reply with quote
The fan I bought and fitted was a basic fan and not a timer fan.
In terms of the wiring I'm not 100& sure. Is there a way to check.
I left the fan on (with isolater switch on) and turned the bathroom light off but unfortunately the fan did not turn off. Does this help at all?
Regards,
BW
Back to top
 Alert Moderators
riveralt
from United Kingdom
Thanked: 565 times
PostPosted: Thu Jan 13, 2011 3:20 pm Reply with quote
Look at the instructions that came with the fan - they will show you how to connect the fan up to the light switch.
If you do not feel confident doing this then I would suggest you get an electrician in - or buy a more appropriate means (Elf & Safety and all that)of ascending up to the isolator switch icon_wink.gif
Back to top
 Alert Moderators
ben85
from United Kingdom
PostPosted: Thu Jan 13, 2011 3:29 pm Reply with quote
Any idea how much an electrician would charge to link the extractor fan to the main light or main switch so it turns on when light on and off when you turn it off?
hopefully 20?
I was going to attempt it but I'm not an electrician and whilst I can change plugs, fuses and simple wiring I think I better not attempt it.
Regards,
BW
Back to top
 Alert Moderators
riveralt
from United Kingdom
Thanked: 565 times
PostPosted: Thu Jan 13, 2011 3:34 pm Reply with quote
hopefully 20?
Regards,
BW
I charge around 160 to supply and fit wall and ceiling mounted extractor fans with all switches and cable where there was none before.
Get 2 or 3 quotes - don't think you are going to get close to 20 though.
Back to top
 Alert Moderators
ben85
from United Kingdom
PostPosted: Thu Jan 13, 2011 3:50 pm Reply with quote
I maybe thought a little low- but with a little bit of wiring needed to connect either main switch, isolater and/or bulb socket- 50 should be more than adequate.
It should only take a decent electrician about 45 minutes if that surely??
Regards,
BW
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1924 times
PostPosted: Thu Jan 13, 2011 3:56 pm Reply with quote
Get 2 or 3 quotes.
It will cost what it costs.
Back to top
 Alert Moderators
riveralt
from United Kingdom
Thanked: 565 times
PostPosted: Thu Jan 13, 2011 3:57 pm Reply with quote
ben85 wrote:
Regards,
BW
It will depend on how the current extractor fan is set up and whether it is legal. Check your instructions but normally there is a requirement in there to say that the circuit must be protected by a double pole FCU with 3Amp fuse.
If everything is in place and legal and the fan draws its power from the same ceiling rose as the light switch then its just a question of making sure the fan's neutral goes to the neutral loop on the ceiling rose and the fan's live goes to the lights switch live on the ceiling rose.
Most extractor fans are double insulated so there is not earth connection to be made.
So it does depend on the amount of work involved - get several quotes though.
Back to top
 Alert Moderators
ben85
from United Kingdom
PostPosted: Thu Jan 13, 2011 3:59 pm Reply with quote
Yep I understand about quotes and cost- I will get 3 quotes.
As mentioned, the fan is double insulated so a slight bonus.
Will update on eventual price..
Regards,
BW
Back to top
 Alert Moderators
ELZ4742
from United Kingdom
Thanked: 16 times
PostPosted: Thu Jan 13, 2011 6:14 pm Reply with quote
you wouldnt get a decent blowy for 20 quid these days* let alone a sparks through your door.
*so Bas once told me
Back to top
 Alert Moderators
ben85
from United Kingdom
PostPosted: Thu Jan 13, 2011 9:37 pm Reply with quote
Yer, I see my price was a little low......
Back to top
 Alert Moderators
1john
from United Kingdom
Thanked: 340 times
PostPosted: Thu Jan 13, 2011 9:44 pm Reply with quote
How many conductors are in the fan, perhaps you have a three core and earth in there and have connected the permanant wire up instead of the switched one, or perhaps some bad egg had used the earth as the switched live, have a check inside the isolator switch.
Back to top
 Alert Moderators
ben85
from United Kingdom
PostPosted: Thu Jan 13, 2011 9:53 pm Reply with quote
When I removed the old knackered fan I just made a not of where they went and then placed them in the same place (wire wise) in the new fan.
I'm going to take picture of isolater soon so you can see all the wires because I'm no electrician so you can determine from the pictures..
It's not the end of the world- if the isolater switch was lower it could just be a simple on/off switch- it's just the fact I have to step on a bin and do it..
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
linking a lighting spur into a two way switch 13 760 Sun Nov 06, 2005 3:32 pm
linking sky 14 440 Thu Jan 20, 2011 9:41 pm
linking earth rods 5 140 Sun Sep 25, 2011 8:14 am
Linking sockets 4 140 Thu Apr 03, 2014 9:29 pm
Smoke/heat detector linking 8 460 Mon Dec 14, 2009 11:57 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
