DIYnot
Local | Network
   DIYnot > Forums
Local | Network
28i RSF and Wireless Towerstat RF ( Selectable Volt Free )
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
lucky1313
from United Kingdom
PostPosted: Mon Feb 28, 2011 10:30 am Reply with quote
Hi
I am trying to fit a Towerstat RF wireless thermostat to my old age boiler a 28i RSF, this is the old grey one with only a mechanical timer unit rather then any thermostat.
I have found a guide that mentions the CM907
http://www.diynot.com/forums/viewtopic.php?p=823347#823347
but i'm not sure what the equivelent AB connections are on the Towerstat
Can any help ?
Back to top
 Alert Moderators
lucky1313
from United Kingdom
PostPosted: Mon Feb 28, 2011 10:53 am Reply with quote
Here is the wiring guide for the Towerstat RF, the cable layout is on page 10
http://www.grasslin-controls.co.uk/assets/graphics/static/STT%20RF.pdf
Many Thanks[/img]
Back to top
 Alert Moderators
lucky1313
from United Kingdom
PostPosted: Mon Feb 28, 2011 11:34 am Reply with quote
Back to top
 Alert Moderators
mikely
from United Kingdom
Thanked: 72 times
PostPosted: Tue Mar 01, 2011 9:06 am Reply with quote
Connect the Towerstat as per the volt free switching diagram on page 10 of the Towerstat manual (link wire removed). Connect ‘Live from load’ to boiler RL (X2 terminal block), ‘Switched live output’ to boiler RI. Also connect live and neutral to the Towerstat from CL and CN terminals.
See boiler installation manual Fig 12 and 13 here: http://www.worcester-bosch.co.uk/cache/file/160/installation-and-servicing-instructions-for-28i--discontinued-nov-05.pdf
Back to top
The following user says thank you to mikely for this useful post:
lucky1313 (1 Mar 2011)
 Alert Moderators
lucky1313
from United Kingdom
PostPosted: Tue Mar 01, 2011 9:18 am Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Danfoss Flow Selectable Valves - rad hot top, cold bottom 8 660 Sun Mar 02, 2008 11:49 am
Volt Free Controls? 2 820 Sat May 19, 2007 11:04 pm
volt free room stat 3 260 Fri Sep 17, 2010 4:41 pm
Volt free thermostat wireing 3 1200 Mon May 17, 2010 10:03 am
relay for volt free switching 28 4440 Mon May 12, 2008 10:06 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
