My problem started when I installed a new digital timer rather and got rid of the old analogue one for the central heating and hot water system. After destroying the first timer by accidently wiring it up wrong, the second one works fine.
However, now the problem is with the valve (model is Honeywell V4073A) which moves a little when the timer switches on and then stops and starts clicking ever few seconds. It's like it's trying to move it but can't after a bit. It ends up that we have the central heating on when only hot water is wanted and since the valve is obviously stuck open it means the radiators get really really hot!
Does anyone have any ideas? I've opened up the motor part and fiddled with it (made it go all the way open and all the way shut manually) but it just moves back and does it's own thing once the power is on. I've sprayed it with WD40 also.
Perhaps I need a new motor as when I killed the first digital timer I may have blown something in that too!
Thanks for your help,
Helen
Helen
