DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Installing gas hob
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
John2512_00
from United Kingdom
PostPosted: Mon Apr 17, 2006 4:18 pm Reply with quote
Hi all, im new to these forums, Im just out my apprenticip as a domestic gas engeneer. CORGI registered (you wouldnt think i was wi these questins lol) I usualy work on CH Systems, repair and service mostly.
But ive never had to work on or install a gas hob before, apart from the cooker in the ACS
Was just checking, the gas hob should be connected by ridgid pipe and not a flexi cooker hose is that right ?
cheers folks
Hope I can start helping folk wi there CH questions and get some knowlege off the guys that have been in the industry a while.
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 438 times
PostPosted: Mon Apr 17, 2006 4:40 pm Reply with quote
This topic has made waves. Very big ones. Topic had been hammered to death.
I would plumb it in 15mm copper and install a stop valve. Would never use a hose (even if maker's instructioned allowed it).
Matter of pride.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 45 times
PostPosted: Mon Apr 17, 2006 5:10 pm Reply with quote
DP is right
am not going to comment re the rubber hose as we have done that to death
good luck mate hope it all goes well with you and your shiney new badge icon_smile.gif
Back to top
 Alert Moderators
bripl
from United Kingdom
PostPosted: Mon Apr 17, 2006 5:38 pm Reply with quote
to connect a gas hob rigid pipe is the only way to do it,have never used a hose for a hob and never will
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 567 times
PostPosted: Mon Apr 17, 2006 6:34 pm Reply with quote
Go for copper - even if hob manufacturer allows it - hose manufacturer almost certainly won't ie ambient temperature too high, contact with oven, unable to hang as a U
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 51 times
PostPosted: Mon Apr 17, 2006 6:35 pm Reply with quote
Yes unless instructed otherwise by manufacturer's instructions.
Back to top
 Alert Moderators
John2512_00
from United Kingdom
PostPosted: Mon Apr 17, 2006 8:36 pm Reply with quote
klkl Cheers guys,
Just been round and fitted it with 15mm Copper and a stop valve.
It was actually my friend that i was fitting it for wanted the hose but i just told him no.
Anyway Ill get on to using the search button soon so as not to bring up teh same stuff all the time.
J
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 916 times
PostPosted: Mon Apr 17, 2006 8:40 pm Reply with quote
err i done mine in 22 mm HEP with a stop cock fitted and it dosen't leak is this wrong icon_lol.gif icon_lol.gif icon_wink.gif
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 45 times
PostPosted: Mon Apr 17, 2006 8:43 pm Reply with quote
dont forget the everflux you use dad
and that blowlamp you use for checking leaks!
( I AM KIDDING DONT DO THIS)
Back to top
 Alert Moderators
JPC
from United Kingdom
Thanked: 19 times
PostPosted: Tue Apr 18, 2006 8:16 am Reply with quote
kev...corgiman...thx both...thats how you do it.
so its ok to use the blowlamp on the hep pipe to check for leaks..great thx
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 946 times
PostPosted: Tue Apr 18, 2006 9:02 am Reply with quote
I don't use 15mm any more, microbore is so much quicker, and a damn site easier if the oven undeneath is tight at the top back.
The drop on a short piece of even 8mm is insignificant. 10mm will go a long way. Compression fitting-reducers are very handy, use the gas cock and one of then to get down from iron or 15 or whatever.
You do need to stock a few fittings for the ends, some hobs needing 3/8" iron connectors etc.
Back to top
 Alert Moderators
Soggy_weetabix
from United Kingdom
PostPosted: Tue Apr 18, 2006 6:59 pm Reply with quote
So can I assume the rubber tube off me u guage and a couple of jubilee clips is not right? Check for leaks with me lighter and if nothing ignites, i do a cut rate deal of 300 quid!
I hope corgi have been notified of a gas appliance install in all seriousness.
David
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 45 times
PostPosted: Tue Apr 18, 2006 7:11 pm Reply with quote
and top point soggy
Back to top
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 438 times
PostPosted: Tue Apr 18, 2006 8:39 pm Reply with quote
David
it will probably be the first hob notified if he has
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 946 times
PostPosted: Tue Apr 18, 2006 11:46 pm Reply with quote
HObs are hard to install properly! Their gas supply is usually teed off the feed to an old boiler so they don't get 20mbar when the boiler's on. It's often way down, so the job's half an hour for the hob and half a day for a new gas line.
But if you ( I mean, I) do a Landlords gas check on a hob installed on 16mbar, it's just " Not to current Standard" which is good enough. Barmy.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Installing a Back-to-Wall WC 2 320 Fri Feb 12, 2010 9:31 am
installing central heating with a concrete floor 2 460 Sat Feb 06, 2010 4:42 pm
installing a central heating system 4 320 Sat Mar 13, 2010 7:44 pm
Installing new shower - moving pipes and wiring 4 80 Fri Jan 21, 2011 10:13 am
Installing a drayton digistat +3RF on a Baxi 105e 5 400 Fri Feb 26, 2010 1:03 pm
DIYnot
