DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wiring a fan from the main circuit
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
  View previous topic :: View next topic
Author Message
thuynh7
from United Kingdom
Thanked: 0 times
PostPosted: Wed Apr 19, 2006 12:21 pm    Post Subject:
Reply with quote Thanks
I\\\'m trying to connect a new extractor fan in my bathroom, it\\\'s powered from the bathroom circuit and not the corded light switch, and the on/off control comes from the fan\\\'s humidity sensor.
Out of the wall comes for wires, red, blue, yellow and earth.
In my fan there are two cables, blue and black, coming from one of those plastic junctions (one is empty). Also the fan does not need to be earthed.
is the correct wiring from wall to fan
red --> blue
blue --> black
yellow --> emtpy
or
blue --> blue
red --> black
yellow --> unconnected.
thanks all
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Wed Apr 19, 2006 4:13 pm    Post Subject:
Are you sure it is a black and not a brown? There is probably a live, switched live, neutral and earth on the supply cable which is the common arrangement for a bathroom fan with a timed run-on, the blue normally being used for neutral connecting to the blue on the fan and the red being permanent live which connects to the brown. If the fan switched on/off by the light pullcord swop red/yellow wires. Terminate the earth into one spare terminal and the switched live into another. You should also have some sort of isolator to allow you to kill the power to the fan for cleaning etc, which if you haven't got is a notifiable job under part p England/Wales to add one.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Sub-circuit off ring main 3 440 Mon Jun 25, 2007 3:57 pm
Motorised blind off lighting circuit or ring main 2 260 Tue Oct 02, 2007 10:05 pm
Lighting circuit powered from 15A ring main 14 1080 Fri Apr 16, 2004 4:22 pm
Single to Double Ring Main Circuit Conversion? 2 300 Mon Jul 30, 2007 8:18 am
Ring main circuit 3 680 Thu Apr 20, 2006 5:24 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
