wd61 tried to escape
31 May 2006
Berkshire
Hotpoint Aquarius 1100 WD61 started jumping about, in middle of normal wash, very violently. Now it will not finish any programmes, dial does not advance automatically. Help!
i would guess it was in a rince cycle?
what were you washing, it is important
had just started a 60 degree wash programme. as soon as the drum started turning it started slamming into units onto either side. was washing two bath sheets. checked the weight it was fine, changed load to full load of tshirts and jeans. same again. now it fills with water and then the controller just clicks and doesnt move.
I am only guessing (because i cant see it)
The tacho magenet may have come off , and or it has gone out of balance, as it shook so violently i would guess it has smahed itself to pieces (i have seen one do this before.)
Time for a hotpoint engineer
if it is over 5 years old it may be a write off.
you could un plug it, open the lid and look (see if the timer is damaged)
