went to a worcester 28cdi the other day.followed fault guide in mi.everything checked out upto last section which stated "change gas valve and if that doesnt work change control board"what sort of fault finding is that.
Is anyone using talc to lube sticky gas valves? I heard about it the other night from a manufacturer (not any of the manufacturers I recommend by the way).
Interesting on my Alpha training it was mentioned that the way a pcb controls a gas valve can mean that one manufacturer has problems with a gas valve sticking from Glycol yet Alpha who use the same gas valve rarely have the problem. It must be something to do with the surge of current at first firing or the degree of modulation for initial fire up.
It would be interesting if some of the folk who complain their boiler won't fire on heating but will on hot water were actually suffering from sticky gas valves that when firing for hot water are dosed with double the voltage at 1/2 or full gas rate as the low rate start up for heating.
Personally I have cleaned a few gas valves and saved people a fortune, but sometimes inexplicably it doesn't work though everything looks and measures right, the critter won't work (but the new gas valve fixes the boiler). Usually on Vokeras. I wander if they don't surge enough power in there at start up?
