DIYnot
Local | Network
   DIYnot > Forums
Local | Network
SP - single-pole, DP - double pole. What does this mean?
Author Message
doh.....
from United Kingdom
PostPosted: Mon May 14, 2007 1:41 pm Reply with quote
I am about to replace some sockets and switches in my house. I have noticed that they come either SP or DP. What does this mean? Which one is better?
Please advise
Many thanks
Back to top
 Alert Moderators
afswift
from United Kingdom
PostPosted: Mon May 14, 2007 1:45 pm Reply with quote
Refers to the switching,
single pole just switches live
double pole switches both live and neutral
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 1 time
Single pole switches disconnect the phase conductor only, while double pole disconnects both phase and neutral.
There is not requirement that you use DP switches but I would recommend it anyway.
*bah!*
Back to top
 Alert Moderators
afswift
from United Kingdom
PostPosted: Mon May 14, 2007 1:46 pm Reply with quote
beat me to it!!
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1435 times
PostPosted: Mon May 14, 2007 1:48 pm Reply with quote
yes, DP is preferable
However, more important still is buying a decent brand.
Crabtree, MK, MEM are all good.
Cheap ones are usually cheap for a reason.
What do you have in mind, and how many? Electrical wholesalers are often cheaper if you are buying a bunch.
Fancy brass and chrome ones are always a lot more more expensive than white.
Back to top
 Alert Moderators
doh.....
from United Kingdom
PostPosted: Mon May 14, 2007 1:59 pm Reply with quote
Was looking at Crabtree or MK. Screwfix seem reasonable. I prefer white because there cheaper but my partner would prefer brushed stainless. Let the battle commence.
Thanks for the help
Back to top
 Alert Moderators
festa
from United Kingdom
PostPosted: Mon May 14, 2007 2:44 pm Reply with quote
T.T earthing systems?
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 145 times
PostPosted: Mon May 14, 2007 3:28 pm Reply with quote
I understand why you should say that, but you're wrong, removeing the plug is allowed as isolation and breaks both poles, the switch is just a functional switch (although some of the newer ones might be approved as isolators... 3mm separatation and all that)
Back to top
 Alert Moderators
festa
from United Kingdom
PostPosted: Tue May 15, 2007 9:37 am Reply with quote
Hi Adam..
Yes a socket outlet can be isolated by switching off and removing the plug but when you have an FCU inline how can you disconnect the neutral then?
Just check OSG page 34 note(ii) for me and let me know im not misunderstanding it as whenever i carry out work on an installation forming part of a T.T earthing system i always replace/install double pole switchgear.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1435 times
PostPosted: Tue May 15, 2007 9:48 am Reply with quote
festa wrote:
.when you have an FCU inline how can you disconnect the neutral then?.
DP FCU of course
Back to top
 Alert Moderators
festa
from United Kingdom
PostPosted: Tue May 15, 2007 10:04 am Reply with quote
Hiya John..
So your saying in a T.T earthing system DP switches are to be used?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1435 times
PostPosted: Tue May 15, 2007 10:07 am Reply with quote
dunno.
I was just saying, if you want to use an FCU, it can be a DP one.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
single/double pole 2 660 Mon Jan 29, 2007 11:08 am
single pole / double pole 4 960 Tue Aug 24, 2004 12:27 pm
Double pole, single gang, switch plug socket. Earth Terminal 9 460 Wed Jan 09, 2013 6:30 pm
Double Pole vs. Single Pole 2 840 Mon May 01, 2006 6:01 pm
double pole or single pole 7 33580 Thu Dec 30, 2004 9:47 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
