DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Overflowing cistern into toilet
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
everclear
from United Kingdom
PostPosted: Wed May 23, 2007 4:51 pm Reply with quote
Hi,first post here and a bit nervous about any plumbing type jobs! icon_eek.gif
We have a centre top push button toilet,just noticed that it overflows down centre pillar flush into the toilet itself,i've tried pulling up the ballcock lever but does not seem to stop the flow of water coming into the 'internal syphon' is it? Do i need to replace this and if so where can i buy one please,i have looked but really confused now! Thanks in advance. icon_wink.gif
Back to top
 Alert Moderators
chr15
from United Kingdom
Thanked: 6 times
PostPosted: Wed May 23, 2007 5:44 pm Reply with quote
There should be some sort of float you can adjust by turning a threaded plastic rod-hard to tell without seeing it-can you post a pic?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1456 times
PostPosted: Wed May 23, 2007 5:49 pm Reply with quote
it will be the ballcock. If new, and it does not stop the flow when fully lifted, it may have a bit of grit or scale in it. You can take it apart and wash it out. Or fit a new one - they only cost a few pounds. A "Torbeck" valve is very quiet in use and slightly dearer. They have a delay of about 10 seconds between being fully lifted and cutting off the flow (this is part of the design).
Back to top
 Alert Moderators
chr15
from United Kingdom
Thanked: 6 times
PostPosted: Wed May 23, 2007 5:55 pm Reply with quote
Didnt think it would have a ballcock john with him saying a centre top push button but I know he mentioned ballcock-so dunno.
Back to top
 Alert Moderators
everclear
from United Kingdom
PostPosted: Wed May 23, 2007 10:39 pm Reply with quote
Ok,took a pic,not great because on phone but should give you a clue. icon_biggrin.gif
http://s203.photobucket.com/albums/aa191/everclear1973/?action=view&current=23052007003.jpg
The water is overflowing into the centre hole and down into the toilet,if i pull up the arm on the left it does not seem to stop the flow.
Back to top
 Alert Moderators
chr15
from United Kingdom
Thanked: 6 times
PostPosted: Wed May 23, 2007 10:59 pm Reply with quote
Ok-not very clear but on the black part where you say you tried lifting the arm,there is a seperate float below it on the same post but lower-cant see from the pic but there is usually a threaded bar or it may just click down but the bottom float needs to be a bit lower to stop it overflowing,thats the best I can tell you without being there! icon_smile.gif
Back to top
 Alert Moderators
everclear
from United Kingdom
PostPosted: Wed May 23, 2007 11:22 pm Reply with quote
Had a fiddle with it icon_eek.gif can't seem to stop it overflowing still,does this pic help more? The float gets to top but does not stop flow.
Back to top
 Alert Moderators
daden
from United Kingdom
PostPosted: Thu May 24, 2007 7:24 am Reply with quote
hi you can try taking the blue(sypon)unit out (put hand on it and turn anticlockwise and pull)when out place in bucket of boiling water for 5 mins replace in reverse order that should work let us no how u got on it could save u buing a sypon
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 1078 times
PostPosted: Thu May 24, 2007 7:36 am Reply with quote
Read this http://www.fluidmaster.com/pdf/400uk_instructions.pdf
and make sure the float doesn't bind on the side of the cistern - also clean off the scale around the side of the float.
Back to top
 Alert Moderators
newboy
from United Kingdom
Thanked: 149 times
PostPosted: Thu May 24, 2007 8:25 am Reply with quote
The valve looks like a 'fluidmaster'
Turn off th supply to the cistern and press down gentlyon the black cap at the top of the valve whilst turning a quarter anti-clockwise. The top should then come off and you can clean the valve out.
Back to top
 Alert Moderators
everclear
from United Kingdom
PostPosted: Thu May 24, 2007 3:57 pm Reply with quote
Yes,it is a fluidmaster,just got it off and found some grit in the seal at the top,gave it a good flush out and clean and now works perfectly! icon_biggrin.gif
Thanks to all of you that gave advice!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Toilet cistern overflowing onto floor! 7 200 Thu Apr 04, 2013 4:47 pm
New toilet, cistern overflowing... 16 620 Thu Mar 01, 2012 8:29 pm
Toilet Cistern Overflowing 2 2520 Tue May 15, 2007 9:59 am
Cold Water Cistern in Attic is overflowing 13 1360 Sun Apr 26, 2009 11:37 am
cistern overflowing 8 80 Wed Aug 24, 2011 4:30 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
